ab43
#1 Posted : Friday, January 2, 2009 8:55:57 AM(UTC)
ab43
My garbage disposal and dishwasher are on the same switch at my circuit breaker. Yesterday I replaced the On/Off switch on my kitchen wall where I turn my disposal on and off (the old one was loose). My garbage disposal works fine, but ever since then, my dishwasher won't turn on. The circuit breaker was off for an hour or so while I made the change.
Any ideas how to troubleshoot this, or is this question better for an electrical forum? Thanks in advance for any help you can provide!
#2 Posted : Saturday, January 3, 2009 4:58:27 AM(UTC)
Sounds like an electrical problem.
You could check the wires at the dishwasher connection/terminal box to see if you have 120 volts.
Also if there were wire nuts in your disposal switch box they may be using it also as a junction box. In other words the power from the circuit breaker box feeds to this box and then to the dishwasher. Open it up again and check the connections.
#3 Posted : Saturday, January 3, 2009 4:24:23 PM(UTC)
Just to add my 2 cents...
Turn the disposal switch "on" and check if the dishwasher works. If it does then there is a wrong connection at the switch.
ab43
#4 Posted : Saturday, January 3, 2009 4:48:12 PM(UTC)
ab43
Thanks all. I wired it incorrectly. I'm back in business.
I'll have to fire my electrician :)
#5 Posted : Saturday, January 3, 2009 10:03:11 PM(UTC)
We are glad you were able to fix it.
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Viking DDB325SS Dishwasher won't start (Dishwasher Repair)
by tmman 6/10/2020 6:44:15 AM(UTC)
Bosch dishwasher won't start after power surge (Dishwasher Repair)
by Larry120 7/17/2018 11:07:27 AM(UTC)
Bosch dishwasher won't start -- display flashes time (Dishwasher Repair)
by rsilk 6/28/2018 6:21:47 PM(UTC)
Dishwasher won't start when house is too cold (Dishwasher Repair)
by manshack_one 1/2/2018 8:13:29 AM(UTC)
dishwasher won't start (Dishwasher Repair)
by goosemasterkl 9/6/2017 5:03:10 PM(UTC)
Ge dishwasher won't start (Dishwasher Repair)
by gegerva 10/9/2016 5:45:31 AM(UTC)
GE dishwasher won't start (Dishwasher Repair)
by tyanbinh 6/10/2016 7:01:58 PM(UTC)
Dishwasher won't start cycle (Dishwasher Repair)
by fugue 4/16/2016 4:33:36 AM(UTC)
Maytag dishwasher won't start unless I manually hold door closed (Dishwasher Repair)
by RepairKing53 1/29/2016 10:14:13 AM(UTC)
by Tricjabs 1/26/2016 5:41:06 PM(UTC)
by Strum310 11/15/2015 5:57:23 PM(UTC)
by dhbrittain 9/9/2015 3:35:11 PM(UTC)
