djupin
#1 Posted : 16 years ago
djupin
My Whirlpool double oven display is blank. Pressing most of the buttons gives a short long short short short beep sequence. Is there anyway to reset this or does one of the modules need to be replaced?
If it a module fault would it be the control panel or the clock control module? I suspect the control module.
Thanks.
Dave Jupin
libertyappl
#2 Posted : 16 years ago
libertyappl
I would check the power supply first, then the thermal fuse on the back and the control board.
Here's your breakdown Model GBD307PDS09
Nat
djupin
#3 Posted : 16 years ago
djupin
I checked the transformer with the power off and got 58.7 ohms on the primary and 2.6 ohms on the secondary. I think that it is OK.
I also checked the thermal fuse on P24 and it seems OK.
The top of the clock control board seems to have some discoloration. I am pretty certain at this point that the board is bad.
I only hope that the display board is also not bad.
Dave Jupin
libertyappl
#4 Posted : 16 years ago
libertyappl
Sounds like the control board is the problem.
nat
djupin
#5 Posted : 16 years ago
djupin
I was able to fix the oven by replacing the control board. Several places that I checked did not have the board in stock - seems like maybe there are a lot of failures of this board.
I was able to get the board from Tribles which is a local appliance parts store. They have a few locations and overnighted it to me from Richmond.
I replaced it Christmas eve and we were able to use it on Christmas.
Dave Jupin
libertyappl
#6 Posted : 16 years ago
libertyappl
Glad you were able to get it fixed!!
Nat
Whirlpool oven problems... (Oven Repair (including Ranges and Cooktops))
by chappy801 13 years ago
Whirlpool oven problems with heating. (Microwave Repair)
by double d 16 years ago
intermittent Whirlpool oven problem (Oven Repair (including Ranges and Cooktops))
by jackchaos 16 years ago
by regent 17 years ago
