One morning my microwave just would not heat. I called Whirlpool they tried to trouble shoot it over the phone and could find nothing wrong. I prayed and the next morning it did work. I tried it the next morning and it did now work. I tried praying and it still does not work. The light,fan,turntable all work. What are common problems with this microwave and how can I fix it?
I have a Goldstar over the range microwave. It was manufactured in April 2007. The model number is MV1610WW, the serial # 704TAYV00682. It was working fine one minute then literally the next no heat. Everything else seems to work fine [, clock, timer, turntable, fan, the light underneath. It just doesn't heat up anything. i used it 5 minutes before and it worked fine. Please, someone tell me if I can fix this and how. It is mounted to the wall above the stove with the backsplash surrounding it, so I hope I do not have to tgake it down to repair or place it. Thanks
same issue with my mv-1565s Originally Posted by: nufam77 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a Goldstar over the range microwave. It was manufactured in April 2007. The model number is MV1610WW, the serial # 704TAYV00682. It was working fine one minute then literally the next no heat. Everything else seems to work fine [, clock, timer, turntable, fan, the light underneath. It just doesn't heat up anything. i used it 5 minutes before and it worked fine. Please, someone tell me if I can fix this and how. It is mounted to the wall above the stove with the backsplash surrounding it, so I hope I do not have to tgake it down to repair or place it. Thanks
Originally Posted by: nizam786 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) same issue with my mv-1565s Please help me. Microwave quit heating but apprears to work in every other way.
