2 Pages12>
dubber
#1 Posted : Thursday, September 1, 2011 12:20:40 PM(UTC)
dubber
Ice maker doesnt seem to be getting water to it but there is water coming out of water dispensor. When hooking up water line I noticed there were two different places you could use one the male threaded fitting same size as a water hose the other, what i am used to seeing, same size as water line. Why two and which one should i use?
magician59
#2 Posted : Friday, September 2, 2011 6:17:33 AM(UTC)
magician59
Your refrigerator's water valve is a dual valve; one side is for the fountain, and the other for the ice maker. Looking at the direction the hoses go, it should be fairly obvious as to which one feeds the ice maker.
There are a couple good ways to test to see if the valve works. Probably the safest way is to remove the ice maker and set it aside, being careful not to spill any water that may be in the ice mold.
Expose the valve, and, since you know that the fountain (water dispenser) already works, exchange the electrical connections to the valve.
Place a cup or other container under the fill tube that feeds the ice maker, to catch any water.
Close the door switch and momentarily depress the water lever on the fountain.
If you get water in the cup, the valve is good; the problem is the ice maker. If you don't get water, the valve is bad. Replace the valve.
Don't forget to replace the valve's electric connectors the way they started.
Part number: AP4511621
dubber
#3 Posted : Friday, September 2, 2011 7:03:43 AM(UTC)
dubber
Thanks So Much! If the valve is bad is it possible to switch the water dispenser one to the ice maskers and do without the fountain?
dubber
#4 Posted : Friday, September 2, 2011 7:12:40 AM(UTC)
dubber
Thanks So Much! If the valve is bad can i switch the two out and do with out the foutain?
dubber
#5 Posted : Friday, September 2, 2011 7:21:27 AM(UTC)
dubber
Originally Posted by: dubber Go to Quoted Post
Thanks So Much! If the valve is bad is it possible to switch the water dispenser one to the ice maskers and do without the fountain? I know I would have to switch hoses, but is this possible?
magician59
#6 Posted : Friday, September 2, 2011 7:23:27 AM(UTC)
magician59
You can do this. But you have to swap the hoses coming from the valve to the unit; and swap the electric connectors. Take a digital picture first, and label the hoses, so that you can replace everything properly, when you get the replacement part.
dubber
#7 Posted : Friday, September 2, 2011 7:28:22 AM(UTC)
dubber
dubber
#8 Posted : Friday, September 2, 2011 7:39:51 AM(UTC)
dubber
dubber
#9 Posted : Friday, September 2, 2011 9:32:22 AM(UTC)
dubber
magician59
#10 Posted : Friday, September 2, 2011 9:36:28 AM(UTC)
magician59
I think there's an echo in here!
Guest (5)
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
2 Pages12>
