likewhoa21
#1 Posted : Monday, August 29, 2011 4:30:22 PM(UTC)
likewhoa21
While troubleshooting a draining issue, I disconnected the wires to the water inlet pump. I did not take note of the wiring configuration and now hot water runs when set to cold (and vise-versa) and the washer does not stop at the end of a cycle - it starts over. Can anyone help me reconnect the 4 wires in the proper configuration?
sidfink43
#2 Posted : Tuesday, August 30, 2011 6:00:24 PM(UTC)
sidfink43
You can either switch the hose connections or switch the connections at the valve assembly to fix the one problem. I don't have this unit in front of me, but usually the hot water connectors are red.
The other is more difficult, probably the timer.
