Laurence23
#1 Posted : Monday, October 29, 2007 7:35:49 PM(UTC)
Laurence23
This is a top load washer 1.5cu (stacked) Recently the washer would not advance and i would hear a humming noise and smell burning. I thought it was the start capacitor. Ohmed it out and it was fine. Then I pulled the motor and checked the transmission. That was fine I actually could turn the coupling (also inspected and fine) and the agitator in the tub spun freely. Checked the pump (also spins freely by hand). So I bought a new motor, cap tube, and start switch installed it and the new motor still humms and will not start the tub spinning. I traced one lead of the start cap tube wire into the timer box. This is the only other thing i can think of that would be the problem i have pretty much elimated every thing else. Has anyone had this problem where the timer was preventing the motor from starting and it was just humming??
ApplianceJunk
#2 Posted : Tuesday, October 30, 2007 4:15:46 AM(UTC)
ApplianceJunk
Hi,
Yes, many times..
Laurence23
#3 Posted : Thursday, November 1, 2007 6:20:49 PM(UTC)
Laurence23
Ok, I replaced the Timer, the motor, the starter, the capacitor, (250.00 bucks) and totally diconnected the motor from the transmission and the pump and the (*&()$#@@ motor still will not start unless i manually give it a good turn (it just humms and starts to overheat).... any suggesting would be great before i go to home depot and spend 1200 bucks on a new washer/dryer and throw this one out the @#@%%^# 'n window. I'm kinda thinking that there must be a voltage issue but not sure how to correct it or what wires to test for what voltage. Any Suggestions would be great :confused:
Laurence23
#4 Posted : Thursday, November 1, 2007 6:59:01 PM(UTC)
Laurence23
250 bucks down the tubes.... by ohming out wires i found a short between the cap. tube and the starter switch..... un real!!!!! a 5" peice of wire was shorted (the connector wire about 1/8" from the terminal somehow pulled away. And I do not mean at the terminal i'm talking in the wire itself. Very unique as far as i'm concerned. Anyone else have this happen to them????? I hope I save some you do it yourselfer's some money.. check the obvious first.... I will say that the machine runs like new...(basically it is new all new parts)!!!
GE 240V Advantium loud humming when plugged in (Microwave Repair)
by Guest 2/27/2024 9:56:42 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
Dryer Timer Humming (Dryer Repair)
by terzolino 4/6/2023 10:18:16 AM(UTC)
Maytag MDBH985AWS Won't Start Motor Humming (Dishwasher Repair)
by pdmac00 10/11/2022 12:48:23 PM(UTC)
Frigidaire Washer FWT449GFS1 won't start or fill will water just makes humming sound (Washer Repair)
by lizard2000 7/6/2021 4:27:51 PM(UTC)
Whirlpool refrigerator making a humming noise (Refrigerator & Freezer Repair)
by manni18 3/4/2021 8:48:14 AM(UTC)
maytag washer hav2557aw (not agitating or spin, humming noise) (Washer Repair)
by davidpr2005 5/27/2020 5:43:37 PM(UTC)
GE Spacemaker JVM3670 (2006) over the range - Intermittent buzzing, humming (Microwave Repair)
by BrucePL 3/5/2019 11:03:39 AM(UTC)
side by side refrigerator started clicking and humming (Refrigerator & Freezer Repair)
by mjkneiser 6/28/2018 8:18:44 AM(UTC)
Microwave Making Loud Humming Sound after Replacing Thermal Flame/Sensor (Microwave Repair)
by BayouDude 1/29/2018 3:38:25 PM(UTC)
Dryer drum not moving freely motor humming (Dryer Repair)
by bluefitness 1/18/2018 4:15:15 PM(UTC)
Front load washer won't start cycles-just humming (Washer Repair)
by Niwashikun 10/16/2017 7:34:20 AM(UTC)
GE - Freezer gets warm, sporadically and humming noise (Refrigerator & Freezer Repair)
by rfranke9 6/13/2017 11:56:10 AM(UTC)
Whirlpool washing will only spin - humming otherwise (Washer Repair)
by chavez 1/11/2017 9:16:17 AM(UTC)
LG dryer makes humming sound for a few seconds when start button is pushed (Dryer Repair)
by vertspd 11/3/2016 7:36:25 AM(UTC)
