nct53
#1 Posted : Wednesday, August 24, 2011 5:16:11 PM(UTC)
nct53
The tech sheet (I was told) was suppose to be in a plastic bag behind the lower panel. The plastic bag was empty. I found a "Duet Job Aid" #68, but it if for models GHW9100L GHW9200L.
Does anyone have the tech sheet for the WFW9200SQA12 unit?
I have a F11 error code, and I know it is a communication error between the Motor Control Board and the Central Control Unit. I have checked all the wiring and cleaned all the connections. My understanding is that the tech sheet will give diagnostic information to check for voltages and such to determine what board it actually is. They are really expensive, so don't want to replace what doesn't need to be replaced.
Thanks in advance for your help!:)
#2 Posted : Thursday, August 25, 2011 4:08:14 AM(UTC)
See the attachment
File Attachment(s):
WFW9200.pdf (617kb) downloaded 206 time(s).
nct53
#3 Posted : Thursday, August 25, 2011 5:56:27 AM(UTC)
nct53
Thank you SO-O-O-O MUCH! This is very different then the one I was able to find. Believe I can "lick the beast" now!
- Noel
