Dryer barely heats up, I need to run a load 3 times before is dry. I would like to check the parts with the Ohm reader as I read on other posts here, my question is, how do I open up the dryer? Help will be appreciated! :rolleyes:
Hi Monica, Is it warm or cold inside the dryer at the end of the cycle? Here are the break down diagrams for the Admiral dryer Model LNC8764A71Gene.
Originally Posted by: Monica  Dryer barely heats up, I need to run a load 3 times before is dry. I would like to check the parts with the Ohm reader as I read on other posts here, my question is, how do I open up the dryer? Help will be appreciated! :rolleyes: In our case, we solved that problem by going on the roof and taking the lint out of the vent there.
