2 Pages12>
Fargon
#1 Posted : 16 years ago
Fargon
I heard a clicking broken gear type of noise and when I opened the door there was no water and it looked like the rotating sprayer on the bottom was not spinning. Broken gear under those 6 or eight bolts on the bottom? Where can I view a schematic? Thanks Fargon
libertyappl
#2 Posted : 16 years ago
libertyappl
Please post the rest of the model number. There should be about 11 numbers total.
Nat
Fargon
#3 Posted : 16 years ago
Fargon
Ok, it's fj4205501
Fargon
#4 Posted : 16 years ago
Fargon
model # 665-15772990. Serial #fj4205501. Michael
Fargon
#5 Posted : 16 years ago
Fargon
I'm running it again, and it's washing just fine so I'll post at what point it starts clicking and what lights are on also. Michael
Fargon
#6 Posted : 16 years ago
Fargon
As an ex trouble shooter for GTE, I know all about trouble that comes and goes. I also know this will likely be back. But I sure would like an experts opinion on this bug. So last time as I said it clicked real loud and no water was coming through the sprayer. At that time two of the three red lights were on and I tried opening the door to restart it a couple of times but it started clicking right away. This time I started it all over and it's three red lights and going gang busters. Thanks for any help. Michael
Fargon
#7 Posted : 16 years ago
Fargon
I removed the lower spray arm and put it right back is the only thing I have done in the middle of all of this. It's running great and almost finished with a load. Mystery to me. Michael
libertyappl
#8 Posted : 16 years ago
libertyappl
Keep an eye/ear on it. Don't want to replace that one with a new one. The new ones don't compare in cleaning, in my opinion. That is one of the better pump & motors that Whirlpool has made.
Nat
Fargon
#9 Posted : 16 years ago
Fargon
So it's the pump system? What would the clicking be exactly? Does the vent assembly need to be cleaned ever? Thanks for your time. Michael
libertyappl
#10 Posted : 16 years ago
libertyappl
No, the water level switch (aka float) was probably stuck. Try trunning a cycle with just white venegar in it to clean the insides.
Nat
jenn-air trash compactor broken gear? (Trash Compactor Repair)
by mljdd 13 years ago
2 Pages12>
