tmwalker3
#1 Posted : Saturday, August 13, 2011 6:19:45 AM(UTC)
tmwalker3
My washer runs fine but when it comes to the rinse cycle it just continually drains, it never fills. All other cycles run great!:confused:
sidfink43
#2 Posted : Saturday, August 13, 2011 6:21:38 PM(UTC)
sidfink43
It is possible that the motor is running in neutral mode and operating the pump but the most likely problem is that you have created a siphon in the drain hose where it goes into the discharge pipe. It is either in too low or it is sealed off so that air cannot get into the drain pipe.
tmwalker3
#3 Posted : Saturday, August 13, 2011 6:53:34 PM(UTC)
tmwalker3
Thanks so much for your help. It was exactly what you said. The drain hose was too tight as soon as I loosened the hose clamp the rinse cycle is filling again! Thanks A Lot!!!!!!!!!:) :) :) :) :) :) :)
sidfink43
#4 Posted : Sunday, August 14, 2011 3:50:28 AM(UTC)
sidfink43
Great, we love those kind of fixes, easy, quick and no cost.
Thanks for the update.
zaphodbblx
#5 Posted : Thursday, February 21, 2013 5:09:35 PM(UTC)
zaphodbblx
thanks for the heads up. just replaced my timer (it was easy...tip though search for the part on amazon I found it 50 dollars cheaper) but after putting it together It wasn't filling for the rinse cycle...turns out i pushed the machine too far in and to the left and kinked the hose...I was seconds away from calling my appliance guy..:)
Kimt
#6 Posted : Friday, August 25, 2017 7:02:36 PM(UTC)
Kimt
This just saved my butt. We moved into a new house and our washer would continually pour water in that immediately drained out. We thought we damage our washer in the move, repair guy charged me $225 to fix my timer and it didn't help. I was about to go buy a new washing machine until I saw this, pulled the drain hose back about 6 inches--problem solved!!!
Help - Maytag Washer Won't Fill On Rinse Cycle (Washer Repair)
by oklanyes 7/25/2015 11:23:28 AM(UTC)
Roper washer won't fill on rinse cycle (Washer Repair)
by goff 12/13/2014 12:14:56 PM(UTC)
by maxy212 10/2/2013 7:01:34 AM(UTC)
Washer won't fill on rinse cycle unless between 2 settings (Washer Repair)
by jkaszer 6/2/2013 11:11:50 AM(UTC)
