harry foy
#1 Posted : Tuesday, December 16, 2008 7:36:19 AM(UTC)
harry foy
Huge ball of lightning struck near my house. Sump pump quit. Oven quit. Either or neither my be a result of surge. Maybe a coincidence. Anyway, not knowing the oven wasn't working, I hit bake and preset first. After a few minutes I increased to 500 deg. to cook pizza. Didn't pay any attention to it. After 10 minutes or so I went to use gas burners and no ignitor. All power was off. Blew circuit breaker. Reset, turned oven on again. Temp would only go to 260, and it took a while. Tried broiler. Only would get partial heat. Neither element would give out normal heat. Baking element is only 2 months old. Broiling element is oringinal and is 2 years old. My question is, can an element be bad if it does produce heat, although not maximum heat? How about thermostat? Thanks for any help.
abadfish66
#2 Posted : Tuesday, December 16, 2008 7:39:46 AM(UTC)
abadfish66
The very first thing I would check is the power. Sounds like you don't have 240volts to the oven, could be a bad breaker. Check the oven where the power cord attaches for a bad connection. Check the outlet with a meter for 240 volts
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Top oven not heating properly (Oven Repair (including Ranges and Cooktops))
by crzyred59 10/25/2015 3:05:35 PM(UTC)
Whirlpool Oven Not Heating Properly (Oven Repair (including Ranges and Cooktops))
by Crash55 1/30/2013 2:08:45 PM(UTC)
older ge oven not heating properly (Oven Repair (including Ranges and Cooktops))
by kris23 2/13/2012 7:11:49 PM(UTC)
Issue with oven not heating properly (Oven Repair (including Ranges and Cooktops))
by LOISANN 1/29/2012 5:46:15 AM(UTC)
Admiral oven not heating properly (Oven Repair (including Ranges and Cooktops))
by scotttheis 5/4/2011 11:44:12 AM(UTC)
by KSimmons 2/12/2011 10:31:01 AM(UTC)
by cougar1963 10/29/2010 7:34:18 AM(UTC)
Gas oven not heating properly (Oven Repair (including Ranges and Cooktops))
by wandanyb 3/17/2010 4:47:18 PM(UTC)
by Jinsmom 1/11/2010 3:48:03 PM(UTC)
Kenmore Dual Fuel - OVEN NOT HEATING PROPERLY (Oven Repair (including Ranges and Cooktops))
by chaznsc 11/19/2009 2:09:20 PM(UTC)
kenmore oven not heating properly (Oven Repair (including Ranges and Cooktops))
by harrymckee 8/16/2008 11:49:48 AM(UTC)
by naholter 12/12/2007 7:22:03 AM(UTC)
by harry-homeowner 8/3/2007 12:38:54 PM(UTC)
