Ericonline
#1 Posted : Wednesday, November 19, 2008 2:52:53 PM(UTC)
Ericonline
My washer began leaking 2 year ago at which time a repair tech came and tightened the bolts around the drum. He said at the time that the seals probably needed to be replaced but this was a huge job and he would have to take the whole washer apart. Anyway, we never had any problems until recently when it began leaking again. I tried tightening these bolts myself and it has helped considerably but it still leaks a little right from the joint where the two peices meet. I also noticed that one of the shock absorbers is broken which explains why it vibrates like a helicopter!
Should I replace the shock and hope that will inturn help vibration and hence not leak?? or should I also replace the drum seal or is that really a "huge job" like he said it was
libertyappl
#2 Posted : Thursday, November 20, 2008 7:51:35 AM(UTC)
libertyappl
You definately need to replace the shock, the seal should probably also be replaced. It is a bigger job, but can be done as well.
Nat
Ericonline
#3 Posted : Thursday, November 20, 2008 8:08:52 AM(UTC)
Ericonline
Thank you! I like tackling jobs like that so I'll give it a whirl. Quick question tho, anywhere I could get a manual or some rough instruction guide on replacing the tub seal?
libertyappl
#4 Posted : Thursday, November 20, 2008 10:10:34 AM(UTC)
libertyappl
This probably isn't like your model but should give you the jest on how to do the repair, since your washer was made by Frigidaire. If this doesn't come thru send me an email and I'll email the manual to you.
http://www.frigidaire.com/tip/s...t/Laundry/5995393138.pdf
Nat
Ericonline
#5 Posted : Monday, December 15, 2008 6:42:03 AM(UTC)
Ericonline
I replaced the tub seal and...HORRAY!!! no more leaks!!!!!!!!!!!!!!!!!!
Thank you for the help!
abadfish66
#6 Posted : Monday, December 15, 2008 6:47:34 AM(UTC)
abadfish66
Wow, your braver than most attempting a job like that...Congrats :)
Ericonline
#7 Posted : Monday, December 15, 2008 6:54:08 AM(UTC)
Ericonline
Thanks...it took me nearly a solid 5 hours on Saturday!!! After I had it all apart I began to wonder if I'd ever get it back together! It was worth it tho. I like tackeling projects like that.
abadfish66
#8 Posted : Monday, December 15, 2008 6:59:39 AM(UTC)
abadfish66
I have had years of experiance on those machines, and takes me 2 1/2 to do that job, so 5 hours for you is pretty darn good.
dave1131
#9 Posted : Sunday, January 11, 2009 7:33:14 AM(UTC)
dave1131
This internet is amazing. I just started having the same problem and need a new gasket. Any other parts to replace or look out for while dis- assembled. Mine is a Kenmore '02.
Thanks, Dave C.
