4 Pages123>»
phillipeharris
#1 Posted : Thursday, December 11, 2008 7:52:45 PM(UTC)
phillipeharris
my dishwasher just started acting up. it does not drain all the way .
I have taken it apart, clean out any buildup (which was none). I checked to make sure that the pump works and it does. the hoses wer not clogged. but I did find that the Piston assembly for check valve
rubber gasket was old and falling apart. will this have an effect on the drainage?
this is the only think that i can see it meesed up on the machine. i dont have a secondary pump on this model so I am at a loss. any help would be welcomed
thanks
phillip harris
#2 Posted : Friday, December 12, 2008 2:34:11 PM(UTC)
Phillip,
The cone part of the piston is very important for proper drainage.
- The part number for the piston & nut assembly is AP2617344
Here are the break down diagrams for the GE dishwasher Model GSD5560G00SS
phillipeharris
#3 Posted : Saturday, December 13, 2008 12:01:52 PM(UTC)
phillipeharris
yea Gene, that is the part I am talking about. it looks like the cone bit is dry rotted. it I replace that will it drain then?
#4 Posted : Saturday, December 13, 2008 4:24:22 PM(UTC)
I wish to know answers on such questions - I would have more $$$ than Bill Gates.
phillipeharris
#5 Posted : Sunday, December 14, 2008 12:04:58 PM(UTC)
phillipeharris
well what does that part do? I just ordered it so we shall see. I will let you know what happens and then you will know as I know.
phil
#6 Posted : Sunday, December 14, 2008 2:52:45 PM(UTC)
Originally Posted by: phillipeharris Go to Quoted Post
...well what does that part do?...
This part works as a directional switch.
dhall4biz
#7 Posted : Monday, December 15, 2008 11:16:46 AM(UTC)
dhall4biz
First, Gene,your posts are excellent and very informative. Many thanks.
Second (and more importantly ;-)), I have similar drainage issues but I am leery of the piston/nut being the cause. The dishwasher drains fine when the discharge tube is lowered, but not when mounted at sink level (where air vent is affixed to sink).
I have cleared all screens and plugs in pipes/tubes and since it drains fine when tube is lowered, it seems to indicate a pump that is beginning to fail (part 325 in diagram?). It just doesn't seem to have enough 'umph' to push water up the extra 18".
I'm not sure what your explanation of the 'directional' function of the piston/nut assembly means...but it would seem to be out of play here since it drains fine if tube is lowered.
Does it seem logical to assume the pump that's failing?
Again, many thanks.
abadfish66
#8 Posted : Monday, December 15, 2008 11:41:46 AM(UTC)
abadfish66
Because it drains with the hose lowered does not mean anything, sorry... When the washer drains, water runs underneath the piston causing it to move upward, and plug the hole in the tub, if this piston head is worn, what happens is as the water is traveling under the piston, the water will travel back into the tub instead of out the drain hose....As for drain pumps, usually they work or they don't. So if the pump is working it is most likely good. Couple things to check, obviously the piston nut. If that is good, meaning a good seal, not a bunch of crud around the spring not letting it close...Take the drain hose off at the dishwasher end, and then unscrew that nipple, and check for debri.....Now I say all this without you posting a model#, so I am assuming you have the same washer as the first post. Not all dishwashers have the same setup.
dhall4biz
#9 Posted : Monday, December 15, 2008 12:11:54 PM(UTC)
dhall4biz
Thanks abadfish66.
I'll revisit the piston/nut conditions. Still seems odd that it drains fine with the tube lowered but not when raised (...maybe a little more pressure coming back on the piston/nut assembly causing it to fail.)
I'll loop back and post my results.
Cheers!
phillipeharris
#10 Posted : Monday, December 22, 2008 7:42:19 AM(UTC)
phillipeharris
Hey man I installed that assembly and it works like a charm thanks for yout help. It only took 5 minutes.
Phil
4 Pages123>»
