bucksuperstereo
#1 Posted : Wednesday, August 3, 2011 6:34:28 AM(UTC)
bucksuperstereo
I'm having a little trouble identifying the right part for my side-by-side fridge. I've searched the forums and know that my door cam broke and caused the issue I am currently having (door used to pop, now hard to close, it will seal...but easily pops open, actually saw pieces of the cam breaking off over the course of 3 weeks).
I took a picture of the appliance sticker inside the fridge part. I think the model number is P/N 241516673, but it doesn't come up in the part search function so I feel like my picture doesn't show the info I need.
UserPostedImageUserPostedImage
It seems as though Part Number: AP2115808 is what I need. Can someone confirm? Also - it looks like both the top and bottom hinge/cam have broken away. Do I need to order two pieces or do they come as a unit?
Thanks for helping!
#2 Posted : Thursday, August 4, 2011 12:53:34 AM(UTC)
The part number on that label may well be the part number of the label.
Check is other areas for the actual model number.
Model Number Locator
bucksuperstereo
#3 Posted : Thursday, August 4, 2011 5:51:25 AM(UTC)
bucksuperstereo
I found what I needed. Both in terms of the model number and then a confirmation of which part I needed. Order is placed and I'm now on step 2 of fixing my door. Thank you!
