We received this oven used from a relative. When I turn on the oven I can smell gas, and it takes quite a while for it to reach temperature. I was told by a friend that I probably needed a thermocoupler, but when I went to live chat here on the site I was told it couldn't be found for this particular model. Any help would be greatly appreciated.
Thanks! Michele
many newer (less than 5 years) gas ovens will read resistance from the glow bar (ignitor) as a type of thermocouple. visualy check the glow bar for discolorations, specificly an ashy spot. if this is the case it is likely your problem. also check you modle # (likely on either the left or right side front when you open the lower drawer
Hi mmorgan100 Most likely the problem with your oven is a bad bake igniter. Replacing it should solve the problem. The bake igniter - The part number for the new igniter AP2020569 Good luck. Gene.
Thanks for your help. Picked up the part today. Just waiting for hubby to get home and put it in. : )
Keep me updated, please.
WOOHOO! All better. It was the ignitor. Thank you so much! We couldn't have done it without you!
