metsmaniac
#1 Posted : Friday, July 29, 2011 8:44:33 AM(UTC)
metsmaniac
I have a Kenmore dryer model #110.66732501 that will not shut off either in the automatic or timed setting. I replaced the timer and that didn't fix it. I replaced the heating element 6 months ago because the dryer wouldn't heat and that fixed the heating problem. I thought I had read on an internet link that the thermostat might need replaced. The dryer was purchased in late 2006.
Any suggestions?
Thanks.
#2 Posted : Saturday, July 30, 2011 2:10:36 AM(UTC)
Here are the parts
Replacement parts for 110.66732501 models | AppliancePartsPros.com
Does the timer advance but just not shut off?
When you replaced the heater was it also not shutting off?
Did this unit used to advance/shut off or has it never done this for you?
This timer runs directly off the 240 in timed dry.
Since you have replaced timer, I would unplug the unit and check the wires to the timer motor and that timer switch 0 timer contacts are closed.
File Attachment(s):
66732501.pdf (267kb) downloaded 78 time(s).
metsmaniac
#3 Posted : Saturday, July 30, 2011 9:30:56 AM(UTC)
metsmaniac
Originally Posted by: denman Go to Quoted Post
Here are the parts
The timer advances but does not shut off.
The dryer was shutting off before & after I replaced the heater.
Sorry, I don't know what you mean by making sure the timer switch 0 timer conacts are closed (not an electrician). Is this something I should be able to do or need a service call?
#4 Posted : Sunday, July 31, 2011 2:44:13 AM(UTC)
Cannot say if you can fix it yourself probably depends how motivated you are to try it.
The timer advances but does it stop advancing at the end of cycle or does it just keep advancing into a new cycle and never stops?
To check the timer switch 0 on the timer.
Unplug the unit and set the timer to just before off on the dial.
Now unplug the TM wire at the timer connections and measure across TM to OR, it should be 0 ohms.
Also could be the heater has grounded.
To check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Kenmore Dryer Won't Shut Off (Dryer Repair)
by TOBY1938 7/23/2014 8:42:08 PM(UTC)
Kenmore dryer won't shut off (Dryer Repair)
by Jerrycurl 5/28/2013 3:39:08 PM(UTC)
