Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You might have an intermittent defrost thermostat, very common. In addition, your adaptive defrost board might be intermittent. You can try just replacing the defrost thermostat and see if that fixes it. If the defrost thermostat is bulged on the plastic top, that would confirm it's bad. Sounds good. I'll try replacing the defrost thermostat to see if that does the trick.
So i installed the replacement defrost thermostat and waited for like a week and sure enough frost started to build up in the back of the freezer. I dont think replacing the defrost thermostat is going to resolve the frost buildup problem. What should I do now?
Did the fridg go into defrost when you tried the second manual test?
I actually didnt try the defrost tests. I just installed the defrost thermostat and hoped that it would work. Should I try the defrost tests again?
Yes before you initiate the defrost test, remove the back freezer panel and check for defrost heat. If the heater fails to come on in a cold freezer, you have a bad defrost heater.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Yes before you initiate the defrost test, remove the back freezer panel and check for defrost heat. If the heater fails to come on in a cold freezer, you have a bad defrost heater. Well I know for a fact that the heater comes on when I unplug the refrigerator, wait like 20 seconds and then plug it back in. After a week or so when the frost builds up i have to remove the panel anyways to ensure that the frost behind the panel is melted. I did a forced defrost a few days ago and saw the heater get hot and turn red, eventually melting the frost that was built up, so i dont think the heater is bad. The last time I tried a defrost test was with the old defrost thermostat and only 1 of the 2 methods worked. Any idea what this might mean?
I would replace the adaptive defrost board I mentioned before.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I would replace the adaptive defrost board I mentioned before. Ok I can try that, however if I replace the board and still have the same issue, does this mean that I'm basically out of luck and will have to buy a new refridgerator? I've replaced the defrost thermostat and now i'll be replacing the adaptive defrost board...could it be something else causing the problem?
All the evidence verifies the wiring is ok, only thing left is the adaptive defrost board.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) All the evidence verifies the wiring is ok, only thing left is the adaptive defrost board. Ok I'll give it a shot. Hopefully this will do the trick :confused:
