3 Pages<123>
#11 Posted : Wednesday, July 27, 2011 1:35:38 PM(UTC)
I do not want to insult you but it may be best to get a pro in.
Your questions just are not in logical order.
I have no problem helping you but things must be done in a logical order or you will just go in circles.
Also it is important that you call the parts by the correct name or it will get very confusing.
For instance you say "motor" but the compressor has a motor and so do the two fans so I do not know what you are referring to.
First I thought that you had already checked and the compressor was running but the fridge was not cooling properly.
Usually you can hear the compressor running also it will be warm and you can feel it vibrating.
So if it is running but not cooling correctly in the freezer you could have 3 possible problems.
A problem in the sealed system OR the evaporator (freezer) fan is not running OR a defrost problem.
You said the evaporator coils were heavily iced/frosted over and this indicates that you have a defrost problem.
So the next step is to check the defrost system as I posted earlier.
The link I posted earlier has a pretty good description of how a fridge works you may want to read that section.
pmase123
#12 Posted : Wednesday, July 27, 2011 2:22:39 PM(UTC)
pmase123
understand that part of it ok... what im saying is when you do the automatic defrost. u turn it off and then click back on. when off i hear nothing running but when turn further to on again everything clicks on again and the frigs clicks on a few sec after. so not sure which defrost problem it would be. i paid someone to come here and tell me that there was a dfrost problem it could be 3 things for defrost problem.. but he wanted 300 dollars to go about and diagnosis it without fixin it... so i choose not to pay him 300 for nothing...
#13 Posted : Thursday, July 28, 2011 1:12:21 AM(UTC)
At 300 bucks they were trying to rip you off.
Perhaps a friend can help you out as two heads are better than one.
I did not understand that you were talking about the defrost timer when you said you were turning it off.
You are not turning the unit off you are turning defrost on.
I think we just have a communication problem.
So lets go through it.
Turn the defrost timer cam until the fans and compressor shut off, you are now in defrost.
Leave it there.
Now check if the defrost heater heats up.
Note: The evaporator coils must still be covered in ice/frost for this to work because the defrost thermostat opens just above freezing and this kills power to the defrost heater.
If the heating element does not heat up then
Unplug the refrigerator.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
pmase123
#14 Posted : Thursday, July 28, 2011 6:42:05 AM(UTC)
pmase123
ok trying to find parts is there another name for the defrost heater .. looking at diagrams and that name is not coming up.. i see a harness in middle of freezer that hooks to something.. could it be called a heater harne???
pmase123
#15 Posted : Thursday, July 28, 2011 6:42:42 AM(UTC)
pmase123
pmase123
#16 Posted : Thursday, July 28, 2011 7:24:05 AM(UTC)
pmase123
ok so i put my hand on everything in freezer and nothing was hot so now im defrosting it to see what is wrong ... hopfully it is the defrost thermostat it is the cheapest.. and i hope it is easy to install..
#17 Posted : Thursday, July 28, 2011 7:25:42 AM(UTC)
Yes that is what it is.
Part number: AP4355467
OR
Part number: AP2071523
The second one is a direct replacement. It includes a defrost thermostat.
The first on is a dual element heater assembly. It does not include a defrost thermostat but supposedly improves defrosting.
Click on the pictures and more info will come up about the part.
pmase123
#18 Posted : Thursday, July 28, 2011 7:29:04 AM(UTC)
pmase123
ya i think i seen metal part at bottom of the freezer.. and it is not hot. . so winting for defrost and maybe i just might replace whole thing if cheap enough might be easier.. probably wouldnt hurt it . ty question are the red and black wire suppose to be hooked to something they dont look to be hooked to anything they are looped and frozen to sides.. but dont looked hooked./
#19 Posted : Thursday, July 28, 2011 10:13:47 AM(UTC)
It is manufactured by GE so I cannot get a wiring diagram.
GE likes to keep everything a secret.
So I cannot say what those wires are for.
Does the heater connect to a defrost thermostat?
It should be clipped onto the evaporator coils.
Part number: AP2071262
Can you see where the wires start and end?
pmase123
#20 Posted : Thursday, July 28, 2011 10:20:56 AM(UTC)
pmase123
yes heyhook didnt see atfirst.. still unthawing but i dot see the thermostat could it be somewhere else in freezer? cause im looking at heater and no thermostat?? it is not sameas diagram in sears parts.. cause heater is at bottom of frig not middle.. this thing is confusing diagram..
Guest (11)
3 Pages<123>
