AndyK
#1 Posted : Wednesday, December 10, 2008 3:10:10 PM(UTC)
AndyK
I have no heat coming out on otherwise good working dryer. I pulled the heating element, which looks fine other than discolored area on plate. Can I check it for continuity? Do I automatically just replace this element or check other sources for problems (such as thermostats and fuses)?
libertyappl
#2 Posted : Wednesday, December 10, 2008 3:12:32 PM(UTC)
libertyappl
Check for continuity on the element and the thermostats. The most common problem is the thermal cut off part # 279816 (Part Details - WHIRLPOOL Thermal cut-off for dryer heating element 309 degrees (includes high-limit thermostat), part number: 279816)
Nat
