elbrecht
#1 Posted : Thursday, December 4, 2008 4:49:30 AM(UTC)
elbrecht
I've had this Whirlpool 1200 dishwasher for about 6 yrs now.
Every couple years it eats an impeller/chopper and I've gotten pretty
good at tearing it down & replacing the thing.
A couple months ago it started a new problem. Every once in a while
there would be [pretty clean] water standing in the dishwasher at the
end of the cycle. [i leave them in over night- it was there in the
morning]
Nothing was leaking so I figured it must be the drain pump- as the
overflow was working somehow. So I got a new pump and all was well
for a while.
Next time there was water standing in it I tried blowing back through
the hose where the drain goes into the disposal. Bubbles came up
in the dishwasher- and it drained when I hit the cancel button.
A couple weeks later it clogged again. This time I thought I'd try to
suck the clog through the pipes. Hooked shop vac to drain at
disposal- tried to suck for a couple minutes. It wouldn't budge. But
I could still blow into that pipe with just a couple pounds pressure
and clear the clog.
Now it is leaking out a little bit during the cycle. Sometimes it
seems to clear itself- as I'll have a puddle, but the drain will be
working by the end of the cycle.
Other times it dumps a quart or so of water on the floor. Sometimes clear- asometimes dirty.
Through all this it seems to be washing the dishes well- glasses and
silverware are rarely spotted.
Any thoughts on where to look?
Thanks,
Jim
#2 Posted : Friday, December 5, 2008 1:38:06 PM(UTC)
Hi Jim,
Did you see where it was leaking from?
The model number you posted does not come up.
elbrecht
#3 Posted : Friday, December 5, 2008 2:43:13 PM(UTC)
elbrecht
Looks like it comes around the left side of the door when the overfill quits working.
Sorry about the model number-- I put an extra 'T' in there- should be GU1200XTLTO.
Jim
#4 Posted : Tuesday, December 9, 2008 2:31:55 PM(UTC)
Hi Jim,
There are a couple things I would check first: the drain hose for a floating foreign object and possible hole in it, and the check valve in the pump sump.
elbrecht
#5 Posted : Tuesday, December 9, 2008 3:10:16 PM(UTC)
elbrecht
Thanks Gene-
I just cured it[?] today.
Seems it was 2 problems. The intermittant clog was the little rubber flapper of the check valve that had come apart-
Model GU1200XTLT0
part number 5 on the pump and motor parts diagram [Part Number: AP3152971 ]
I tore things down to where I could see the inlets to both pumps and ran 3 cycles before it clogged again. Then I blew like hell on the drain hose back towards the dishwasher, and the little rubber disk appeared.
The leak seems to be a bad door seal as I don't get any standing water now- but it still leaks & it is definately around the door. Parts about $20 apiece.
I'll know for sure next week- but I think life is good.
Jim
#6 Posted : Wednesday, December 10, 2008 8:27:37 AM(UTC)
Jim,
I'm glad you found it.
