marv
#1 Posted : 17 years ago
marv
i fix the heat and it only last 1 or 2 days ?????????????:mad:i have changed the thermal cut-off and the thermal fuse the cut off gose out in 1 or 2 days what do i do
fixxit
#2 Posted : 17 years ago
fixxit
when you replace the thermal cutout you should also change out the operating thermostat as it is probably why the cut out went. good luck and post your results here
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 12 months ago
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius about a year ago
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 2 years ago
Kenmore Dryer spinning cold air nonstop until the door is open (Dryer Repair)
by Guest 2 years ago
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 2 years ago
Kenmore dryer issue when heat is on (Dryer Repair)
Kenmore Dryer Model:86984110 (Dryer Repair)
by CarolynC143 2 years ago
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 3 years ago
Repair manual for Kenmore dryer model 110.85081401 (Washer Repair)
kenmore dryer wiring (General Talk)
by epyveras 3 years ago
KENMORE DRYER WIRING 796.813 (Dryer Repair)
Kenmore Dryer Model 110.76752500 Parts (Dryer Repair)
by redknitter 3 years ago
kenmore dryer powers up with lights on, push start and it chirps and that is all (Dryer Repair)
Kenmore Dryer 41790052990 (Dryer Repair)
by Guest 4 years ago
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 4 years ago
