washer starts okay, then washes very slowly,spins slowly, doesn't remove water, seems to be leaking through assembly where water leaves thru belt wheel.
It sounds like your tub seal has failed, and water has leaked into the transmission causing your problems. I think a new machine would be in order.
Sorry not to have better news.
