pmmr
#1 Posted : 17 years ago
pmmr
Dryer spins up, but, will not heat. I have 110v coming down on red lead, and the return wire appears to switch when push to start button is depressed. I have continuity on the flame sensor and I tested the glow ignitor with a cheater cord, it heated up to red and glowing. I measured about 500 ohms across the 2 connector coil and about 1500 across the 3 connector coil. Are these coils bad? Do you know where I can get a electrical schematic? Thanks, Pat
#2 Posted : 17 years ago
Hi Pat
The first thing I would check is the thermal fuse on the back of the dryer behind the cover. It's located on the air duct. Replace it if it's open.
According to the manufacturer recommendation, if the thermal fuse is blown, the cycling thermostat has to be replaced too. It's located next to the thermal fuse.
The thermal fuse
UserPostedImage
The cycling thermostat
UserPostedImage
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX5636AW1
Good luck.
pmmr
#3 Posted : 17 years ago
pmmr
Thanks, but, the two wires coming down to the assembly seem to be switching, would that be happening if the thermal was blown? I will check tonight. Also, I found the breakdown drawings earlier, I am looking for an electrical one line drawing, thanks. Pat
pmmr
#4 Posted : 17 years ago
pmmr
Thermal fuse is ok, now what? Thanks
#5 Posted : 17 years ago
Hi Pam
I found the wiring diagram for your dryer. The gas dryer diagram is on page 2.
I hope it will help.
pmmr
#6 Posted : 17 years ago
pmmr
Thanks for the drawing, that helps greatly. I made a mistake, the fuse was bad, will change both as suggested.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 2 years ago
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 4 years ago
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 4 years ago
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 4 years ago
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 4 years ago
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 7 years ago
Dryer won't heat (Dryer Repair)
by ncoles6 8 years ago
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 8 years ago
by Kate123 9 years ago
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 9 years ago
by haymon 9 years ago
by wgomezp1 9 years ago
by chash 10 years ago
Gas dryer won't heat (Dryer Repair)
by pino2424 10 years ago
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 10 years ago
