2 Pages12>
compton
#1 Posted : 16 years ago
compton
My kenmore 90 series washer spins but won't agitate. You can't turn it either way by hand. When the tub spins clothes get caught in the agitator causing it not to spin unless you take some out and move them away from agitor to sides of tub. Agitator does not spin in spin mode. Coupling is fine. What could b the problem? The washer is a direct drive. MODEL # 110.22922100
libertyappl
#2 Posted : 16 years ago
libertyappl
Please post your model number off the washer.
Nat
compton
#3 Posted : 16 years ago
compton
Model #110.22922100
libertyappl
#4 Posted : 16 years ago
libertyappl
Does the bottom part agitate at all?
Nat
compton
#5 Posted : 16 years ago
compton
It Agitates A Little Back N Forth Clockwise And Back Conterclockwise Less Than A Quarter Turn. It Won't Spin When Tub Spins. My girlfriend washed some heavy rugs n its been doing it ever since.
compton
#6 Posted : 16 years ago
compton
Somebody please help out. I have looked at everything. ?????
magician59
#7 Posted : 16 years ago
magician59
Replace the agitator dogs.
compton
#8 Posted : 16 years ago
compton
Thanks for the tip. I will try that and see if it works. I have them out and gonna replace them, but I didn't realize that would cause the bottom agitator to not spin in spin mode.
compton
#9 Posted : 16 years ago
compton
Replaced Agitator Dogs And Problem Stiil Exist. Bottom Agitator Will Not Spin When The Tub Spins In Rinse Or Spin Mode Causing Clothes To Wrap Around Bottom Agitator. On To Next Suggestion. coupling is fine!
libertyappl
#10 Posted : 16 years ago
libertyappl
Did you check the coupler between the motor and the pump?
Nat
Kenmore 90 series agitator (Washer Repair)
by helpme 17 years ago
2 Pages12>
