oldyeller
#1 Posted : Monday, December 1, 2008 2:52:06 PM(UTC)
oldyeller
Some buttons on my touchpad quit working.
1) I'm having trouble getting to the touchpad. My unit is mounted above my stove. I removed the bottom plate and depressed the two locks holding in the touchpad frame, but could not pry it away.
2) Once I get to the touchpad, how do I verify that it's the touchpad that's bad?
Regards,
Jim
#2 Posted : Tuesday, December 2, 2008 2:28:57 PM(UTC)
Hi Jim,
If some buttons on the touch pad are not working then the touch pad most likely is bad.
The model number you posted does not come up.
