Darren
#1 Posted : Saturday, September 29, 2007 8:11:22 AM(UTC)
Darren
I am not sure about the age of the washer. I changed the agitators about 4 months ago and everything has been fine. Today we heard a different noise and it was the motor running but it is not spinning.
From what I can tell look at the breakout it could be a clutch?
What do you think and what ever you suggest is it hard to replace?
Darren
jdappl07
#2 Posted : Wednesday, October 24, 2007 8:11:34 PM(UTC)
jdappl07
if the machine will not aggitate if is the motor coupling if it does then its a clutch also see if something is in the pump
angcal
#3 Posted : Thursday, October 25, 2007 8:57:41 AM(UTC)
angcal
My GE Washer model # (wpsf4170w0aa) my ge washer mackes loud moises when spinning and if the load is slightly heavy it will not spin can you help
richappy
#4 Posted : Friday, October 26, 2007 1:26:40 AM(UTC)
richappy
You have a Whirlpool washer! If it will not agitate also=bad coupler.
If failed in spin, you may have something caught in the tub or dragging brake shoes. Shine a light in basket and check for stuff, if ok, replace the coupler and turn tranny coupler clockwise till the basket starts to spin. If hard to turn with one hand, you have dragging brake shoes. Post results.
#5 Posted : Friday, October 26, 2007 12:41:51 PM(UTC)
Hi angcal
The first thing I would check is the belt. Replace it if it's worn out.
If there is nothing wrong with the belt then most likely the problem is a bad transmission.
- Here are the break down diagrams for the GE washer Model WPSF4170W0AA
Good luck.
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
by howard6168 7/5/2015 5:47:41 AM(UTC)
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 6/18/2015 12:01:29 PM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
washer will not spin out (Washer Repair)
by kdwarren16yrs 12/27/2014 6:42:50 AM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
Washer will not spin/drain (work) (Washer Repair)
by dupdc 8/20/2014 2:50:08 AM(UTC)
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 5/7/2014 6:40:52 PM(UTC)
