gdriekho@ctcis.net
#1 Posted : Saturday, June 25, 2011 12:54:54 PM(UTC)
gdriekho@ctcis.net
This side-by-side has stopped cooling, both fridge and freezer. It is just over one year old....figures, it's out of warranty. About every couple minutes I can hear the compressor start (at least I hear a normal sound as if it's starting to run) and it runs for about 6-8 seconds and then cuts out. Is there a user fix, or do I have to call in the experts?
gdriekho@ctcis.net
#2 Posted : Saturday, June 25, 2011 1:11:22 PM(UTC)
gdriekho@ctcis.net
Forgot to mention that on the LCD display there is the number "6" with two rings moving outward around the number. If this is some sort of error code, I can't find anything in Whirlpool literature that tells what the number means.
richappy
#3 Posted : Sunday, June 26, 2011 12:36:23 AM(UTC)
richappy
I would try a new start device AP4369220 and see what happens. If you have an amprobe, check compressor current at startup.
