Martha Shelby
#1 Posted : Tuesday, October 23, 2007 8:00:21 AM(UTC)
Martha Shelby
The washer will was but will not go into the rinse or spin cycle. You can hear a small humming noise....any suggestions of what might be wrong?
jdappl07
#2 Posted : Wednesday, October 24, 2007 8:02:38 PM(UTC)
jdappl07
pull the pump off the front of the motor and jump the lid switch with a wire between the two wires ([COLOR="Red"]not the green one[/COLOR])start it in spin. If it goes replace pump if not pull motor off maybe broken motor coupler if not it is the clutch assy
richappy
#3 Posted : Thursday, October 25, 2007 1:43:03 AM(UTC)
richappy
If the washer agitates ok, but no spin, it's probably a bad timer.If no agitate, probably a bad coupler.
Roper washer will not spin or drain (Washer Repair)
by Jfriedm 6/15/2010 5:37:38 AM(UTC)
Washer will not spin or drain (Washer Repair)
by templejazz82 6/24/2009 4:55:28 AM(UTC)
washer will not spin or drain - leaks (Washer Repair)
by BARCHER 4/29/2009 6:23:57 AM(UTC)
by Martha Shelby 10/23/2007 8:01:38 AM(UTC)
