i replaced rubber drain impeller (maytag part #900894) with the gray center up, and the white center down. i didnt take notice when i removed the old one. is this correct? thanks
These two parts have a graphite rings (bearings). The black on one and the white on another one. They must face each other.
![UserPostedImage](http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfNDk4MDA5L0dBVFlBTS9nbWl0cmFwLw%3d%3d) Impeller Part Number: AP397341 Manufacturer's Number: 900894 made by MAYTAG ![UserPostedImage](http://www.appliancepartspros.com/img/dot_216.gif) Our Price: $8.29 Compare at: $15.39 You Save: $7.10 ![UserPostedImage](http://www.appliancepartspros.com/img/p.gif) Availability: In Stock Order now and it will ship Monday ![UserPostedImage](http://www.appliancepartspros.com/img/p.gif) Quantity
Different views available: ![UserPostedImage](http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjJfaHQ0OTgwMDkvR0FUWUFNL2dtaXRyYXAv)
If you are talking about impeller only, then the white part should face down, toward the black graphite ring on the bottom seal.
