AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Help... my microwave is less than 2 years old and it is not working!
My microwave appears to be working. The table turns, the light is on, it makes noise, but no heat is being generated. Is this easy to fix? It is a 2006, is it under warranty?
Hard to say if it is an easy fix. Here is the tech sheet https://www.servicematters.com/d...0Sheet%20-%208205609.pdfYou say it makes noise but can you hear the magnetron turning on/off at a 50% heat setting? Usually is a slight buzz (not loud) or the unit sounds like it is bearing down. If yes then your magnetron is probably shot. Could be one of the thermostats/cutoffs is open. Remove the wire from one side of each of them and check them for continuity with a meter. Looked up your unit on the Whirlpool website, says it only has one year warranty. |
THIS FORUM IS DEAD!!!!!!! |
Microwave Repair
