Princess65
#1 Posted : Thursday, June 16, 2011 5:43:03 PM(UTC)
Princess65
Hello
I'm trying too see what part I need for this washer...The water goes in the washer but it doesn't spin it only spins when its on the spin cycle
Joe / APP Team
#2 Posted : Friday, June 17, 2011 12:33:25 PM(UTC)
Joe / APP Team
Originally Posted by: Princess65 Go to Quoted Post
Hello
Princess,
If you mean the washer won't drain,
Check for a kinked drain hose, check for a clogged drain pump or a clog in the tub to pump hose.
You may need a drain pump, if the impeller fins are damaged,
Part number: AP4027705
Good Luck,
Magtag washer security lid lock key breaks off then goe’s flying (Washer Repair)
by Stevethebrain 11/25/2017 6:33:23 AM(UTC)
How to Hold Magtag Bravos Tub from Turning While Loosening Bolt? (Washer Repair)
by Twang 3/7/2017 3:24:28 AM(UTC)
Magtag wont tumble (Dryer Repair)
by george28 10/14/2013 9:00:13 AM(UTC)
Magtag washer quiet series 100 (Washer Repair)
by kajohn 7/10/2013 8:14:22 PM(UTC)
Magtag washer only spins (Washer Repair)
by taxesbytina 4/28/2013 4:05:40 PM(UTC)
bottons on magtag micowave not getting any power the it stays on zero (Microwave Repair)
by work2do2 4/17/2013 7:13:56 PM(UTC)
Magtag washer not spinning, smoking belts (Washer Repair)
by mekon 9/27/2012 11:00:27 AM(UTC)
Magtag (Heating, Ventilation, and Air Conditioning (HVAC))
by cflick 6/16/2012 4:13:39 AM(UTC)
Magtag Bravo (Washer Repair)
by MEMEROUDY 1/4/2012 3:12:19 PM(UTC)
Magtag Washer Motor (Dryer Repair)
by Terry505x 8/15/2011 7:57:18 AM(UTC)
Split in Magtag washer door seal (Washer Repair)
by Callalillie 7/25/2011 2:10:46 PM(UTC)
Magtag not spinning (Washer Repair)
by P51302 5/28/2011 8:43:52 AM(UTC)
Magtag oven repair (Oven Repair (including Ranges and Cooktops))
by batman721 3/25/2011 1:11:29 PM(UTC)
magtag performa shuts itself off (Dryer Repair)
by gypsy608 2/4/2011 2:02:22 PM(UTC)
Magtag aggitator comes apart? (Washer Repair)
by keithmcintyre 1/31/2011 1:11:21 PM(UTC)
