5 Pages«<345
#41 Posted : Tuesday, June 14, 2011 3:04:02 PM(UTC)
It is shown as #12 on the diagram.
Here are the breakdown diagrams and Replacement parts for THERMADOR PRG364GDUS GAS RANGE | AppliancePartsPros.com
nexttw
#42 Posted : Tuesday, June 14, 2011 3:08:44 PM(UTC)
nexttw
Found the simmer controller at the front left bottom of the range. Will test it using the flow diagram. Will keep you posted Gene. Thanks for your help.
nexttw
#43 Posted : Tuesday, June 14, 2011 9:00:57 PM(UTC)
nexttw
Hi Gene,
Good news,...
Went thru the flow chart and everything went as planned.
It turned out that it was indeed a bad solenoid. Once I replaced that, everything was operating back to normal.
Thanks again for you input and this forum! :)
#44 Posted : Tuesday, June 14, 2011 9:41:29 PM(UTC)
You are welcome. I'm glad it's up and running.
Guest (5)
5 Pages«<345
