25 Pages<12345>»
nschwaber
#21 Posted : Wednesday, June 8, 2011 12:33:43 AM(UTC)
nschwaber
I have a similar issue to the other folks in this thread.
Water dispenses fine. Ice maker makes ice sporaticlly, maybe once or twice a day. When I close the emmiter door I have no red LED. If I close the door switch at the top of the freezer the LED starts blinking.
Thanks,
Nathan
#22 Posted : Wednesday, June 8, 2011 12:36:40 PM(UTC)
Nathan,
What is the exact measured temperature in the freezer?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRG25FKSS15 REFRIGERATOR | AppliancePartsPros.com
nschwaber
#23 Posted : Wednesday, June 8, 2011 8:44:01 PM(UTC)
nschwaber
Thanks for the reply Gene -
It seems that the temperature would be a simple thing to get, however modenr houshold thermomethers both mercury and digital don't go below 90 degrees.
Any suggestions?
Nathan
#24 Posted : Wednesday, June 8, 2011 9:02:27 PM(UTC)
Nathan,
I'm afraid there is much more serious problem than not working ice maker. Looks like your refrigerator is not cooling properly. 90°F is warmer than the temperature in the kitchen. You have to call a certified tech to check the sealed system.
nschwaber
#25 Posted : Wednesday, June 8, 2011 9:15:11 PM(UTC)
nschwaber
Sorry Gene... I think you miss-understood my reply. My freezer is not 90 degrees, infact it's quite cold. I was mearly saying that the generic household thermometers (the kind you use when your sick) don't register below 90 degrees.
So with that I was unable to answer your original question of how cold is the freezer. Other than saying everything in there is frozen properly I can't get an exact reading.
Nathan
#26 Posted : Saturday, June 11, 2011 6:08:58 PM(UTC)
Sorry for this misunderstanding.
Looks like you have to buy a special refrigerator thermometer. They usually priced bellow $10 and you can find them at many stores.
kfinitz
#27 Posted : Saturday, June 11, 2011 9:31:05 PM(UTC)
kfinitz
Similar problem here too! I have a KitchenAid side by side KSRA25ILSS03 and my ice maker stopped working all the sudden. The ice in the door works fine and I can put already made ice in the dispenser and it will dispense it from the door. When I manually close the flap on the left side the sensor light stays solid red but when I release the flap the red lite blinks twice and then off, twice and then off, twice and then off... Any ideas?:rolleyes:
melaniel
#28 Posted : Monday, June 13, 2011 1:50:32 AM(UTC)
melaniel
I have a siimilar problem as well. I have a Kitchenaid refrigerator that the icemaker has quit working. When I open the door the LED flashes twice. When i close the flap on the left the LED on the right stays on. When I simulate the door closing the light goes off. Is this a bad icemaker? MOdel no. KSRW25CRSS01
Read more: http://forum.appliancepartspros...post462462#ixzz1P9E7HrpO
http://forum.appliancepartspros.com
#29 Posted : Monday, June 13, 2011 4:36:08 PM(UTC)
Remove the ice maker (the instructions are attached) but do not disconnect the wire harness. Check the water feeding tube for any icicles or frost inside.
If there are any, defrost it using a hair dryer.
If it is clear, remove the ice maker head cover and check for 120 VAC between the "L" & "N" test points. Make sure the test probes go in at least 1/2".
Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRA25ILSS03 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
File Attachment(s):
Removing the ice maker - in door ice system 2.doc (522kb) downloaded 240 time(s).
#30 Posted : Monday, June 13, 2011 4:41:17 PM(UTC)
You can use the same instructions as I posted for [COLOR="Red"]kfinitz[/COLOR].
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRW25CRSS01 REFRIGERATOR | AppliancePartsPros.com
Guest (10)
25 Pages<12345>»
