Hi,
My washer fills up with water (only the cold water) and continues to fill even though the washer is unplugged. The only way I can turn it off is close the cold water valve going into the washer. I had quite a flood, before I discovered it wasn't shutting off. Is this a water inlet valve problem? Thanks:confused:
