Set cycle hit start and washer buzzes and agitates in one direction but wont spin or drain. please help.
Inside the lower service panel are tech notes that will show you how to generate error codes and do certain diagnostics. From the sound of things I think the problem is likely in the speed/motor control board, but you will need to check it out to be certain.
