2 Pages12>
ccredsox
#1 Posted : Sunday, November 23, 2008 9:41:38 AM(UTC)
ccredsox
All of the sudden a loud humming noise is coming from the machine. Sounds like a motor is stuck or something. Are there belts on this model that could have broken and need to be replaced? I checked the inlet screens for blockage and the drain pipe (figured I would try the easy stuff first) but no luck. The machine is still filling fine but I think its something wrong with the spin cycle. Any help would be greatly appreciated!
ccredsox
#2 Posted : Monday, November 24, 2008 5:41:38 AM(UTC)
ccredsox
please help!
v2k04
#3 Posted : Monday, November 24, 2008 6:10:13 AM(UTC)
v2k04
Check the pump there may be something in it and if there is it will make a horrific howl,squeal,whatever
ccredsox
#4 Posted : Monday, November 24, 2008 6:23:16 AM(UTC)
ccredsox
Is the best way to check the pump by tipping over the machine and accessing it that way?
Thanks!
magician59
#5 Posted : Monday, November 24, 2008 6:43:06 AM(UTC)
magician59
If it drains, but doesn't spin, you'll need to replace the motor coupler assembly (a relatively easy job).
ccredsox
#6 Posted : Monday, November 24, 2008 7:06:24 AM(UTC)
ccredsox
and what is the best way to get access to this coupler assembly?
ccredsox
#7 Posted : Monday, November 24, 2008 2:41:49 PM(UTC)
ccredsox
So I tipped over the washer to gain access to the pump and coupler and they both seem fine. I can spin the internal pump (thingy) which in turn rotated the coupler. I couldn't find anything restricting the flow of water either. After I uprighted the machine I turned it on and It was making the same noise; a loud grind/squealing noise that sounds as if its something that rotates. It only happens during the spin cycle and the machine continues to fill and drain fine.
Help!
richappy
#8 Posted : Tuesday, November 25, 2008 2:51:58 AM(UTC)
richappy
Pull off the control panel screws, tilt it back and remove the lid switch plug and the top panel clips. Then take off the outer cover, remove the pump and motor.
Turn the coupler clockwise until the spin basket starts to turn. If very hard to turn it further, you either have something obstruction in the tub, of bad brake shoes.
ccredsox
#9 Posted : Tuesday, November 25, 2008 4:19:59 AM(UTC)
ccredsox
Is it straight forward to take the outer cover off? A handful of 3/8" Hex Heads accessible from the bottom?
richappy
#10 Posted : Tuesday, November 25, 2008 5:39:14 AM(UTC)
richappy
Your panel screws are in the back on each side, just unscrew both pull forward and tilt panel back.
I would advise to fix this soon, I have seen too many burnt motors from this kind of failure!
Loud Humming noise (Microwave Repair)
by fjmcfall 6/3/2015 7:41:20 AM(UTC)
Whirlpool refrigerator has a loud humming noise (Refrigerator & Freezer Repair)
by jkjk 5/10/2012 11:38:12 AM(UTC)
Washer is working fine, but makes loud humming noise... (Washer Repair)
by erica2713 4/8/2011 12:56:23 PM(UTC)
Kenmore coldspot fridge making a new loud humming noise? (Refrigerator & Freezer Repair)
by CRISBD 11/16/2010 12:56:41 PM(UTC)
Dishwasher started making loud humming noise (Dishwasher Repair)
by desh 3/27/2010 1:31:07 PM(UTC)
Maytag Performa loud humming noise (Washer Repair)
by a1_sullivan 1/3/2010 4:57:32 AM(UTC)
Intermittent loud humming noise (Refrigerator & Freezer Repair)
by clarencew 1/23/2009 9:45:46 AM(UTC)
Microwave makes loud humming noise (Microwave Repair)
by aussie downunder 10/19/2008 7:48:02 PM(UTC)
by Fritzauf 7/22/2008 7:20:46 PM(UTC)
Spacemaker JVM1660SB008: No Heating Loud Humming Noise (Microwave Repair)
by Doppan 1/27/2008 9:18:53 AM(UTC)
2 Pages12>
