tarikkabbaj
#1 Posted : Tuesday, June 7, 2011 1:47:49 PM(UTC)
tarikkabbaj
Hello,
My freezer is working but my refregirator gets warm. I tried to locate the defrost timer to test it but I could not find it. please advise! thanks,
Tarik
#2 Posted : Tuesday, June 7, 2011 4:32:31 PM(UTC)
Replacement parts for WHIRLPOOL GS5SHAXNB00 REFRIGERATOR | AppliancePartsPros.com
See the attachment for the tech sheet
You do not have a defrost timer, defrost is controlled by the main control board (Item 18 in Section 11).
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle, see the tech sheet when the fans and compressor turn off you are in defrost.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 33 in Section 11) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK. It seems it is missing from the parts breakdown but there will be one clipped to the evaporator coils.
If both the above are OK then odds are the control board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
File Attachment(s):
GS5SH.pdf (700kb) downloaded 92 time(s).
tarikkabbaj
#3 Posted : Tuesday, June 7, 2011 7:09:07 PM(UTC)
tarikkabbaj
Thank you Denman, I will need to replace the electric board. Is it easy to change?and what is the process? thanks again for you advise
Tarik,
#4 Posted : Wednesday, June 8, 2011 3:34:48 AM(UTC)
[COLOR="DarkRed"]Is it easy to change?and what is the process?[/COLOR]
Should not be that difficult though I have never done one.
Just be sure to unplug the unit.
Also touch a ground before handling the board to get rid of any static electricity your body may be holding.
If you has copper plumbing pipes then one of them will do.
fyrestiks
#5 Posted : Tuesday, January 5, 2016 11:32:44 AM(UTC)
fyrestiks
Whirlpool Gold refrigerator model GS5SHAXNQ00
The freezer side is working fine, refrigerator side will not cool and is warm. Took cover off inside freezer, ice and frost on coils.
Have no idea how to check if defrost thermostat is bad or how to manually put in defrost mode
Any insight would be greatly appreciated
#6 Posted : Tuesday, January 5, 2016 12:08:15 PM(UTC)
fyrestiks
Parts for Whirlpool GS5SHAXNQ00 Refrigerator - AppliancePartsPros.com
The procedure to force a defrost cycle is attached to my earli8er post. Your unit is the same.
Jump defrost timer (Refrigerator & Freezer Repair)
by baechlem 4/21/2020 12:21:48 PM(UTC)
Can't find the defrost timer (Refrigerator & Freezer Repair)
by Ardee348 3/14/2020 12:52:47 PM(UTC)
Refrigerator defrost timer (Refrigerator & Freezer Repair)
by Cabob 3/12/2019 5:38:53 AM(UTC)
Defrost Timer Setting (Refrigerator & Freezer Repair)
by Rattletrap45 11/21/2018 5:30:39 AM(UTC)
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 6/6/2018 5:18:48 PM(UTC)
Refrigerator shuts off after replacing defrost timer (Refrigerator & Freezer Repair)
by Blaine211 9/13/2017 4:44:33 PM(UTC)
Frigidaire defrost timer (Refrigerator & Freezer Repair)
by Jefe60 9/9/2017 1:57:46 PM(UTC)
setting a defrost timer (Refrigerator & Freezer Repair)
by e4g76 6/30/2017 1:15:41 PM(UTC)
Where is the defrost timer located on Amana ARS2667AW (Refrigerator & Freezer Repair)
by f117b2 6/9/2017 4:55:09 AM(UTC)
GE Fridge running a little hot bad defrost timer/compressor? (Refrigerator & Freezer Repair)
by Maddrnkm 4/14/2017 3:27:39 PM(UTC)
by rt4x4 4/4/2017 9:01:48 AM(UTC)
New defrost timer requires tap to start (Refrigerator & Freezer Repair)
by Donro 10/5/2016 8:37:14 AM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Defrost timer stops turning (Refrigerator & Freezer Repair)
by Defroster 7/31/2016 1:24:37 PM(UTC)
Four defrost timers ALL bad? (Refrigerator & Freezer Repair)
by Defroster 12/6/2015 7:30:28 PM(UTC)
