cannot get ac unit to run i believe that the problem is with the thermostadt wiring i have a standard 5 connector themastate with the the 5 connetions being labled as white , (red-h) , (red-c),green ,yellow all are hooked up correctly except (red-c ) on the furnace controll board i have ( C , R , W, G,Y, ) all are hooked up accordingly except (c )the furnace heats durring the winter like it is supposed to now heres the problem i am having i have the two wires comming from the outside unit ( red and yellow ) where do i need to connect these wires to make the ac work in conjuction with the furnace yes the a coil is installed and i can maneually start the outside unit by pressing the button on the contacts any info would be greatly appreciated :confused:
Red wire goes to Rc terminal on thermostat (may need to jumper Rc-Rh) Yellow wire goes to Y terminal on thermostat (this is for compressor contactor coil)
