VWC318
#1 Posted: : Friday, November 21, 2008 2:04:56 PM(UTC)
VWC318
Can someone tell me what steps are required to remove the oven door from my Kitchenaid KEMS306XWH5 and once it's removed how it is disassembled to replace the inner glass? Thanks
libertyappl
#2 Posted : Friday, November 21, 2008 2:31:11 PM(UTC)
libertyappl
Looking at the parts breakdowns help, Model KEMS306XWH5
Nat
VWC318
#3 Posted : Friday, November 21, 2008 2:41:30 PM(UTC)
VWC318
Do I need to remove the door first?
libertyappl
#4 Posted : Friday, November 21, 2008 3:44:31 PM(UTC)
libertyappl
It will be easier if you do.
Nat
VWC318
#5 Posted : Friday, November 21, 2008 3:53:09 PM(UTC)
VWC318
Do I lift the door off the hinges or is the door attached to the hinges by screws? The diagram is unclear on this.
libertyappl
#6 Posted : Friday, November 21, 2008 6:47:10 PM(UTC)
libertyappl
I think you lift the door up then out, each model is a little different.
Nat
VWC318
#7 Posted : Saturday, November 22, 2008 3:46:19 AM(UTC)
VWC318
Thanks for your help Nat. You've been a big help to me.
libertyappl
#8 Posted : Saturday, November 22, 2008 6:29:27 AM(UTC)
libertyappl
Glad to help keep us posted.
Nat
VWC318
#9 Posted : Monday, December 15, 2008 1:47:12 PM(UTC)
VWC318
We were unable to figure out how the door comes off the hinges as my friend never saw a hinge setup like the Kitchenaid. But we were able to take the door apart, replace the broken inner glass and put it all back together.
CraigKAnderson
#10 Posted : Friday, August 27, 2010 2:18:19 PM(UTC)
CraigKAnderson
Most of the Whirlpool ovens have an extra hole in the hinge. Insert a nail or Allen Key on each side. Cautiously close the door and like magic, the hinges pop out of the oven frame.
