heidibobb
#1 Posted : Tuesday, May 31, 2011 2:38:06 PM(UTC)
heidibobb
We had a power surge from a storm that burned out the board.
I am trying to remove it but having trouble. I removed the 4 screws, but I can't disconnect the wires inside. Any ideas?
sidfink43
#2 Posted : Thursday, June 2, 2011 5:33:22 PM(UTC)
sidfink43
I don't have one in front of me, but here is what the service manual says to do.
The main control board and touch screen LCD
are attached to the backsplash as one unit. The touch screen LCD and main control board are only available as a complete assembly.
To remove the main control board and LCD touch screen assembly:
1. Remove the Backsplash.
2. Disconnect the ribbon at the right of the main control board.
Note: Do not disconnect any other ribbons from the main control board.
Disconnect Ribbon
3. Remove the 4 Phillips head screws (2 on each side) that hold the main control board and LCD touch screen assembly in place. Remove the assembly.
