2 Pages12>
hart7220
#1 Posted : Friday, October 19, 2007 2:50:46 PM(UTC)
hart7220
Washer cycles and drains fine but it only spins for about 5 seconds.
#2 Posted : Friday, October 19, 2007 3:19:30 PM(UTC)
Hi hart7220
Most likely the problem with your washer is a bad control board. It's not repairable and has to be replaced.
- The part number for the new control assembly AP3140343
- Here are the break down diagrams for the GE washer Model WCSE3100A1WW
Good luck.
hart7220
#3 Posted : Friday, October 19, 2007 3:25:56 PM(UTC)
hart7220
Thanks so much Gene , the part has been ordered!
#4 Posted : Friday, October 19, 2007 3:46:27 PM(UTC)
Keep me updated, please.
richappy
#5 Posted : Saturday, October 20, 2007 2:18:13 AM(UTC)
richappy
GE has had a lot of problems with motors. Before replacing control board, which might just blow out when you turn on the washer, check the motor current, if over 10 amps, you have a shorted centrifical switch in the motor. You can click on your model # to order it.If you remove front panel and measure voltage to the motor. If ok when it shuts off this confirms new motor time.
hart7220
#6 Posted : Monday, October 22, 2007 5:02:21 PM(UTC)
hart7220
I got a new control board and still have the same problem. If the centrifical switch is bad doe's that mean that I need a whole new motor? Please help, thanks, Neal.
#7 Posted : Monday, October 22, 2007 5:14:56 PM(UTC)
GE does not sell parts for the motor separate which means you have to buy the whole motor with the clutch assembly.
- The part number for the motor AP3160670
hart7220
#8 Posted : Monday, October 22, 2007 5:20:32 PM(UTC)
hart7220
Do you think it's worth putting this kind of money into this machine?
#9 Posted : Monday, October 22, 2007 5:23:18 PM(UTC)
Depends on the age and condition.
hart7220
#10 Posted : Wednesday, October 24, 2007 3:24:21 PM(UTC)
hart7220
Just wanted to let you know that the spin cycle is now working. Could the motor still possibly be a problem? Thanks, Neal.
Guest (5)
GE washer won't spin, smells like burning rubber (Washer Repair)
by TimBlock 12/27/2015 12:35:03 PM(UTC)
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 12/21/2015 10:19:03 AM(UTC)
GE washer won't spin during final rinse (Washer Repair)
by Asu19 10/28/2015 2:38:21 PM(UTC)
GE Washer won't spin or agitate (Washer Repair)
by whovian2015 9/30/2015 2:56:35 PM(UTC)
GE washer won't spin (Washer Repair)
by Dana021 4/28/2014 5:05:18 PM(UTC)
GE Washer Won't Spin - Lid Lock Error? (Washer Repair)
by lum 1/30/2014 11:41:30 PM(UTC)
GE Washer won't spin dry clothes (Washer Repair)
by jglascoe1691 12/10/2013 4:41:11 AM(UTC)
GE washer won't spin/agitate (Washer Repair)
by Mlsmith 10/8/2013 5:30:10 PM(UTC)
GE washer won't spin or agitate (Washer Repair)
by unclejohnforever 2/27/2013 6:58:56 AM(UTC)
GE washer won't spin - Mark (Washer Repair)
by masavrin@netzero.net 1/2/2013 9:45:50 AM(UTC)
by the5tjrs 11/2/2012 9:01:04 AM(UTC)
GE Washer won't spin with heavy loads (Washer Repair)
by paulgj 10/18/2012 8:00:50 PM(UTC)
ge washer won't spin (Dishwasher Repair)
by magsw 5/24/2012 3:12:19 PM(UTC)
ge washer won't spin or wash, no blinking lights on motor (Washer Repair)
by fr45 2/28/2012 9:22:19 AM(UTC)
GE Washer won't spin but agitates (Washer Repair)
by guptamgs@hotmail.com 1/5/2012 11:29:15 AM(UTC)
2 Pages12>
