rcarroll7703
#1 Posted : Wednesday, June 1, 2011 7:50:27 AM(UTC)
rcarroll7703
My washer started leaking today. Seems to be on the drain cycle. It leaks form the left side. No apparent leaks on the fill cycle. washer may not be draining completely.
rcarroll7703
#2 Posted : Wednesday, June 1, 2011 8:24:59 PM(UTC)
rcarroll7703
In response to my earlier inquiry, I've discovered a possibility to my own question. It seems that I have a defective pressure switch. The washer does not stop filling once a reasonable water level is reached. I'm trying a smaller load setting now to see what the cut off threshold is.
sidfink43
#3 Posted : Thursday, June 2, 2011 5:25:25 PM(UTC)
sidfink43
That will do it, go ahead and replace the switch, you will be much happier for doing that.
rcarroll7703
#4 Posted : Thursday, June 2, 2011 7:55:24 PM(UTC)
rcarroll7703
Thanks, the part should show up mon. after lengthy observation, i'm convinced this is the culprit.
Leaking Washer (Washer Repair)
by midget73 7/27/2014 3:27:00 PM(UTC)
by broonsparrow 11/30/2013 10:15:30 AM(UTC)
Leaking washer need advice (Washer Repair)
by GE Nightmare 10/5/2013 1:54:30 PM(UTC)
leaking washer (Washer Repair)
by ashkdaot 6/25/2013 6:23:18 PM(UTC)
by Jags 12/22/2012 8:37:52 AM(UTC)
by martha725 8/3/2012 2:11:37 PM(UTC)
leaking washer and won't drain (Dishwasher Repair)
by colt 11/6/2011 2:15:14 PM(UTC)
leaking washer (Oven Repair (including Ranges and Cooktops))
by cheery 11/5/2011 6:14:56 PM(UTC)
Leaking washer (Washer Repair)
by Crowell 9/6/2011 9:11:30 AM(UTC)
leaking washer during filling (Washer Repair)
by bonnetinsurance 8/10/2011 7:44:44 AM(UTC)
by 03svrider 6/9/2011 10:48:37 AM(UTC)
by donandlynn 5/7/2011 7:32:41 AM(UTC)
by Mrkis 1/30/2011 9:09:01 AM(UTC)
by Clueless101 12/27/2010 12:33:13 PM(UTC)
by wirenutt2 12/6/2010 9:44:26 PM(UTC)
