Replacement parts for SX25SW models | AppliancePartsPros.comSee the attachment for the tech sheet
Sounds like you have a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle (see the tech sheet ). When the fans the fans and compressor turn off you are in a defrost cycle.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 28 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 26 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the adaptive defrost board (Item 26 in Section 9) is toast
File Attachment(s):
SX25.pdf (1,149kb) downloaded 59 time(s).
