4 Pages<1234>
abadfish66
#21 Posted : Monday, November 17, 2008 9:49:44 AM(UTC)
abadfish66
The part# to fix the freezing water line on the GE SxS refer made between 2003 and 2007 is WR49x10173
wb2nco
#22 Posted : Thursday, November 20, 2008 7:11:29 AM(UTC)
wb2nco
I jumped online and found an inlet valve and installed. Wala!! Problem is fixed! Water now comes out of the dispenser! I now have 2 new valves after $50 in parts and my wife thinking that I'm overly obsessive!:rolleyes:
Now another issue!:confused:
Water does not exactly stop coming out when I release the switch. It goes for about another 20-30 seconds. I have to stop about half way filling a glass. Also water does seem to come out a bit slower compared to what I have seen with other units. It might be normal, I'm not sure? Anyway, what can I do about the streaming water still coming out after I release the switch?
libertyappl
#23 Posted : Thursday, November 20, 2008 7:34:11 AM(UTC)
libertyappl
Run about a half a gallon of waterthru it to get all the air out of the lines and it should stop doing that.
Nat
wb2nco
#24 Posted : Friday, November 21, 2008 8:22:45 AM(UTC)
wb2nco
I ran several gallons of water and it still runs quite a bit after depressing the button. Any other ideas?
abadfish66
#25 Posted : Friday, November 21, 2008 8:28:05 AM(UTC)
abadfish66
Does your refer have a water tank reservoir, if it does, it will be behind one of your drawers in the freshfood section. if it does, you may have air trapped in that, take it off and turn it upside down and call for water, this will remove the air pocket in the tank
wb2nco
#26 Posted : Friday, November 21, 2008 9:52:38 AM(UTC)
wb2nco
Yes there is a tank inside the frig. Does it need to be filled entirely to start off? Should it always be full as I dispense water?
I assume water is drawn from the dispenser to the front of the door. Water then is pumped back in the tank from one of the valves? Should the tank always be full?
libertyappl
#27 Posted : Friday, November 21, 2008 9:59:29 AM(UTC)
libertyappl
The tank should be full, if it has an air pocket in it you will have the symptoms you are getting do as abadfish stated above.
Nat
wb2nco
#28 Posted : Saturday, November 22, 2008 10:50:29 AM(UTC)
wb2nco
That worked like a charm!! Thank you all for your help! This site helped me save time and money!!
libertyappl
#29 Posted : Saturday, November 22, 2008 11:15:42 AM(UTC)
libertyappl
Glad you were able to get it fixed!1
Nat
debbya
#30 Posted : Saturday, November 22, 2008 3:47:17 PM(UTC)
debbya
Do you know where to find the valve if you have determined it is not working properly?
Guest (11)
4 Pages<1234>
