3 Pages123>
cfilice
#1 Posted : Thursday, November 13, 2008 5:38:30 PM(UTC)
cfilice
for some reason, my dacor double wall ovens wont illuminate ( inside the oven ) when the lite buttons on the panel are pushed ( there are two buttons, one for upper oven and one for lower ). Any ideas would be appreciated.
#2 Posted : Thursday, November 13, 2008 7:08:55 PM(UTC)
The first thing I would check are the light bulbs.
cfilice
#3 Posted : Friday, November 14, 2008 6:35:44 AM(UTC)
cfilice
Gene, I will check the bulbs. But, since they both failed at the same time, it seems unlikely. Is there anything that could cause both lite switches to fail at the same time ( something in the control panel )?
#4 Posted : Friday, November 14, 2008 11:10:06 AM(UTC)
Lets do one thing at a time. Check the light bulbs first.
Is there push in switch on the door frame or just the pad on the control panel? What is the complete model number of the oven?
cfilice
#5 Posted : Tuesday, November 18, 2008 9:09:28 AM(UTC)
cfilice
Gene, no buttons on the door. The model number is MCS 227S.
cfilice
#6 Posted : Tuesday, November 18, 2008 9:12:20 AM(UTC)
cfilice
Gene, also, I did check one of the bulbs ( there are four total, two in each oven ). The bulb was fine. There are two buttons on the control panel. One for the upper oven and one for the lower. Neither button causes anything to happen.
magician59
#7 Posted : Tuesday, November 18, 2008 9:47:47 AM(UTC)
magician59
Do you hear the faint click of a relay when you press a button, or no sound at all?
cfilice
#8 Posted : Tuesday, November 18, 2008 10:36:33 AM(UTC)
cfilice
No, absolutely no sound at all on either button.
magician59
#9 Posted : Tuesday, November 18, 2008 10:49:25 AM(UTC)
magician59
I suspect a bad relay or control board.
#10 Posted : Tuesday, November 18, 2008 12:45:05 PM(UTC)
Open the control panel and check the low voltage lights transformer. The lights in this oven are a halogen 10W 12V, so there suppose to be 12V at the secondary windings. Here are the wiring diagrams for this oven.
- The part number for the transformer is AP3391742
Guest (6)
3 Pages123>
