The buttons on the top of my door panel do not work as well as the start/cancel button. The heavy wash, heat dry, hi temp, 2H light up, however I can not start the dishwasher. What parts do I order?
Originally Posted by: karen Dellert ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The buttons on the top of my door panel do not work as well as the start/cancel button. The heavy wash, heat dry, hi temp, 2H light up, however I can not start the dishwasher. What parts do I order? Karen, You most likely have a bad touchpad assembly, that will require replacement of the control panel. Part number: AP4365089
If you have access to a multi meter, you could check the resistance of the buttons that don't work, to verify it, and go from there. :) :) :)
