joeblue
#1 Posted : Sunday, May 22, 2011 9:14:11 AM(UTC)
joeblue
Makes creaking/ squeaking noise sounds like bearing when I ture the drum by hand but it also makes it and a loud banging noises during spin when the shocks are really moving and to top it off there's water leaking onto the floor. Removed lower front panel and it looks like the water is leaking towards the back so does a seal fail when a bearing goes out. Please help and thanks. I mean really three problems all at once. Should I find the nearest cliff and push the washer off.
sidfink43
#2 Posted : Monday, May 23, 2011 2:49:06 PM(UTC)
sidfink43
If the bearing is gone, and it sounds like it is, then you do need to go cliff hunting.
At this point with your machine a replacement is the best option.
joeblue
#3 Posted : Monday, May 23, 2011 5:24:13 PM(UTC)
joeblue
OK, that's what I thought. I understand that some of these machines are prone to this type of failure. Thank you very much for getting back to me it means alot.:cool:
sidfink43
#4 Posted : Tuesday, May 24, 2011 3:34:49 AM(UTC)
sidfink43
No problem, yes this machine is very prone to the problem you have.
Good luck with your new machine.
