ARRABITOT
#1 Posted : Friday, October 19, 2007 4:41:02 PM(UTC)
ARRABITOT
The dryer will start but shuts off in 10 seconds. I removed the belt to see if the drum was putting any drag on the motor. The motor spins freeely by hand, but when starting it runs then stops in 10 seconds.
Jesus Gutierrez
#2 Posted : Friday, October 19, 2007 6:06:12 PM(UTC)
Jesus Gutierrez
The motor is pulling high amperage and over load is opening. Could be the age of motor or motor needs a good cleaning.
richappy
#3 Posted : Saturday, October 20, 2007 1:37:45 AM(UTC)
richappy
Sounds like a stuck centrifical switch on the motor. Check for motor high current like over 10 amps. Callappliancepartspros, they may have one for your dryer.
Maytag Dryer shutting off after 2 minutes (Dryer Repair)
by Guest 11/9/2023 4:45:11 AM(UTC)
maytag dryer MEDC200XW1 (Dryer Repair)
by patnok 9/4/2023 8:02:13 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Maytag dryer (Mode MEDC300XW1) not starting, but runs only in Wrinkle Prevent cycle. (Dryer Repair)
by Guest 7/28/2022 6:31:22 PM(UTC)
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
Maytag Dryer Slow to Spin after parts replacement (Dryer Repair)
by steelwindmachine 8/18/2021 5:58:15 AM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Maytag dryer MDE9316ATA (Dryer Repair)
by Guest 5/1/2021 3:45:42 PM(UTC)
Maytag Dryer (Bravos) (Dryer Repair)
by Kap61 3/29/2021 4:03:51 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
Maytag Dryer Starts But No Heat (Dryer Repair)
by boonie785 6/1/2020 3:32:33 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
MAYTAG dryer loud squealing/squeaking (Dryer Repair)
by joenobodyyet 3/24/2020 1:27:25 PM(UTC)
