I have a whirlpool duet washer model number ghw9400pw0 that is displaying a f 05 code. I replaced the heating elememt and the ntc sensor and it is still displaying the code. What should I check or replace next?
The F05 code is: Water Temperature Sensor Error
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the “F/05” error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay • Check connections to the Sensor, Heating Element and Relay
F/H F/02 F/05
Nat
I replaced the sensor and the element but I do not know whaere the relay is to check and what to check for. Please advise. Thanks
See If This Manual Will Help You Out. Nat
I have the f05 error code too. I also have replaced the ntc sensor (figured why not it was 10 bucks) but i am still getting the error code. any luck with the relay??? any other suggestions would be greatly appreciated.
thanks!
