Burner will shut off after 20 seconds and come back on seconds later for maybe ten seconds and then shut off again...replaced coils/and thermal fuse...still problem persist...any ideas how i should proceed? thanks for any help guys!
Mike Maytag Model: mgd5700tq0
Ok no replys yet, anybody got an idea what to check next? could it be flame sensor?? the initial problem was no heat at all , replaced fuse and now burner comes on for less then 20 second intervals and doesnt dry well...can someone please help me out with some advice? thanks!!
Mike
Originally Posted by: indiana324 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Burner will shut off after 20 seconds and come back on seconds later for maybe ten seconds and then shut off again...replaced coils/and thermal fuse...still problem persist...any ideas how i should proceed? thanks for any help guys!
Mike Maytag Model: mgd5700tq0 I have a 7-year old Maytag that is intermittently not heating well. I am still troubleshooting as to when it does and does not. What I have found initially is that the "intellidry" sensor lights (wet/damp/dry) come on at random times during the Intellidry cycle. As I write, the dryer is heating well on the timed cycle. Guessing that the sensor may be bad. I do not know if this may apply to your model. Will update as I find out more... Matt Maytag model: mgd7400aww
